First Run
tup48
As the subject line implies: this is the first run for my ¼ Scale Rider-Ericsson Hot-Air Engine and pump.
You can see it at: [ame]http://www.youtube.com/watch?v=m92kvTmIHV0[/ame]
I got the castings in Feb. of this year. Thy are the first set of castings that I have work with so far. I found this engine very interesting to build and the best part is it runs.
Now all I have to do is tear it down, paint it, put it back to gather and hope that it will still run.
Richard
Beautiful job Richard, and obviously a nice runner too. Can you show/elaborate some on what you are using to heat it with. I purchased the castings back in January and will be working on this as my next build.
Again....very nice work!!!
Bill
Congratulations Richard! Welcome to the world of the oil-spotted! Thm:
Bill:
When you got your castings you should have got a sheet with the planes for a Gas Burner Assembly, if not let me know and I can e-mail you copy of the sheet. I got myself a cheap propane torch for the shut-off valve and a way to hook the burner to a small propane tank.
It seems to take a lot of heat to get the engine to start but not a lot to keep it running.
I made the burner out of brass just because that was what I had and I used the head of the torch for part of the burner but did have to drill out the orifice/gas jet to about 0.04” and put in a different venture to get it to work. By using the torch as part of the burner I don’t think I saved any time and may have ended up doing more work in the end.
Richard
That has to be the wildest sounding engine I've ever heard. Great looking also. I can't tell the size from the video though. Can you post a photo with something to reference the size by.
Thanks
What a great little engine :D love seeing it pump water too !! Congratulations !!
Will R
Richard,
Nice job. :bow: :bow:
Best Regards
Thanks for the info Richard. I probably have the plans in the plan set, and will look now to be sure. Since the build is still a few months out, I honestly haven't looked at the plans yet so as to keep them more intact for when I do start the build. Hope I can do it as well as you have :)
Bill
