I finished this horizontal engine yesterday. The original plans were bought on E-Bay and set around for a year until I came up with what I liked and wanted to change. No personal name to credit. ( " Is it broken ? " ) I kept the overall size and spool valve.
I made the cylinder and valve all one piece, added bushings to the connecting rod, made the cross slide assembly separate, the cylinder is a thru bore and the piston and rod at the head and spool valve have o-rings. I used needle roller bearings for the crank with a piece of Thompson rod for the shaft. Made the flywheel with curved spokes and corrected a tracking problem with the eccentric rod end running on the cam with some spiral retaining rings. Brass spacers on the crank rod and locations of set screws.
With the 1" bore and 30 lbs. of air it has some power and it self starts. Happy with the results.
Click image to play.
