Fastener info
chucketn
Senior Citizen
Near Jonesborough, TN
Another thread info document:
http://homepages.cae.wisc.edu/~me232/tolerance_info/fastener_handout.pdf
Found this while trying to figure out what thread size is on a potentiometer I want to use in a power supply. The thread is definitely 32tpi, but major dia. Has me confused. The thread measures .3095 with my digital calipers. Falls between 1/4 and 5/16. I lost the nuts for the pot and need to make one but can't figure out what tap to use.
Chuck in E. TN
I'd say your thread is 5/16x32, the 0.003 thou difference between 5/16 and your 0.3095 is negligable and could just be down to tightening teh die a fraction.
This is a standard ME thread here but its likely to be UNEF for you
http://www.sizes.com/tools/thread_american.htm
J
They tend to cut the threads a little small on those so they can fit through a drilled hole without a lot of cleanup..
