vederstein
Must do dumb things....
- Feb 26, 2011
- 932
- 776
A thanks to Todd Snouffer for the link.
Continuing on with the build....
The prints call out some spherical ball end joints for the displacer rod. Alas, I don't have a ball turner. Therefore I went as far as I could as shown below. Because these parts (at least for me) are tiny I knew there'd be no way I could hold a cut to length round black for the milling operations. Therefore I turned the parts on the two ends of the provided barstock. This way once I was at the mill, hopefully I could stay at the mill.
Then placing the blank into my rotary table, I could locate, drill the holes and mill the side flats...
Then I parted off the end to length.
Then back to the mill. I turned the rotary table 90 degrees then rounded the end. This is a potentially dangerous setup and I recognized the risks and mitigated. When doing this, up-milling is critical so that the part doesn't grab into the mill and take your fingers with it. My fingers did not become a piece of stock for the endmill to cut.
A little filing to smooth the edges and I'm calling these parts done (Yes the parts have two difference hole diameters)...
