Milling lobes starts in 0 degree position.
1.pic. here is milling depth of lobe in my case 2 mm.
Then secure height of milling bit for rest of work.
2.pic. milling lobe in CCW direction , turning lobe in 2 degrees increments
till 120 degrees is reached.
3.pic. return lobe to 0 degree position and mill lobe in CW direction
till - 120 degrees.First lobe done.
4.pic. return lobe to the 0 degree and attach second arrow points to 0 degree.
Then release screw what secures camshaft pull camshaft out
to see second lobe./DO NOT MOVE ROTATIONAL UNIT/
5.pic. turn camshaft till second arrow points to 100 degrees CW and secure it in this position.
6.pic. milling second lobe in the same way as described above.
Lobes timing angle is variable for CW and CCW running engines.
