- Aug 25, 2007
- 3,890
- 715
Yet another project, kind of a filler project while I'm remodeling the kitchen. Actually, SWBO is remodeling, I'm just the grunt.
I built this model a number of years ago. I love the flywheel, which I cast from Zinc Aluminum alloy. I also like the brass column. However, it was a single acting oscillator which didn't seem very exciting and I always wanted to "make it better". Here is a before picture of the engine:
So, I'm converting it to a double acting oscillator with an epicyclic gear train for the crank, similar to the large oscillator mechanism in another post: http://www.homemodelenginemachinist.com/index.php?topic=8531.0
So far I've calculated position and drilled all the air holes and cylinder mounting holes in the brass column. I've also made the cylinder. I'm planning to use a 12 tooth pinion on the crankshaft and a 20 tooth pinion on the connecting rod. This will give me something better than a 2 to 1 ratio of the flywheel to the piston cycles.
Chuck
Chuck
