Hi Dave,
Thanks - I'm very pleased with it too ;D
No, it's not a typo, but there's reasons behind it. Firstly, as it was running lights out I didn't want to come back in the next day to find a scrapper in the mill, so the feeds and speeds were wound right the way down to around 600rpm and 40mm/min, and I think it worked out to be nice and gentle on the cutter too, as the same TiCN coated two fluter did the whole of the roughing and finishing.
Secondly, we have only one full 3D Gibbs seat in the building, which unfortunately isn't on my computer. So whilst I can use it, for jobs that needs adjustment or tweaking I tend to use the 2.5D seat on my machine to save p*ssing off the user of the 3D seat, which by giving it the outlines and the 3D model, produces results that are good enough for hand finishing. But, the real downside with that is that you lose the full control over the profiling operations, so the cutter tends to spend a reasonable amount of time in fresh air...
Still, it got there in the end!
Lol, just a few hours
With the trims, I'd got the corners mounted first, and then machined the convex and concave profiles milled as lengths. But to ensure a good fit to mate to the vagaries of my filing and polishing on the corners, each length of trim has been hand filed and fettled to the correct end profile to mate with the corners. It probably sounds like moaning, but they have to be filed very carefully and gently to try and ensure no gaps. Drives me nuts to be honest!
Thanks again,
