It has been a while since I posted to this thread
Soooo
this is where I am at.
The Emco 120P lathe has had a birthday,
* Spindle rebuilt
* Auto tool turret rebuilt
* Auto Tail-stock rebuilt
* Chuck actuator rebuilt
* New 85mm chuck fitted, also have the 5C collet closer
* Panels sandblasted and powdercoated
* New stepper motors fitted
* 2K painted several components
It is dummy assembled at the moment
I still need to powdercoat the base now and cut some perspex to fit the door etc
re-assemble and she will be up and running again.
This machine was good before, should be like new when finished. This is the only Emco 120P cnc I know of in Perth and one of 6 I know of in the country. I would love to get my hands on a few more of these machines and enough work too keep them busy full time.
I have retained the original stepper pulleys and belts
There is a 2.2kw 3 phase and vfd motor mounted, (5000 rpm spindle)
I am running an Andrew Barrow etc board for the atc.
I am going to run a mini atx motherboard and stepper drives, b/o board etc all mounted in the original electrical box mounted on the side of the machine
This is when I first purchased the machine
Here is a couple of pictures after rebuilding the ATC,tailstock etc and painiting with 2K paint
Here is a of picture of the 2.2kw motor and vfd
I made a new motor pulley to suit the motor shaft. The old pulley was seized on the original spindle drive.
the Autogrip 3P-03 chuck that I found.
This chuck mounts directly to the spindle although needs an adaptor for the actuator-chuck made
And a few pictures of the panels after powder-coating. The base still needs to be done and I also have taken the old stickers off very carefully and my local sign writer is making some new ones for me which will be identical.
This is a pretty basic build compared to some of the other tasks I have undertaken so I don't know what else to say really. The pictures don't do it much justice. It looks great in real.
Cheers.
Baz.
