Almost June 2010. Almost good weather outside the half-opened window in our little apartment near the northern end of the orange line. Almost scrapped the almost finished crankshaft from near 6 months ago...
I'm trying to turn the crankshaft for the 1/4 scale version of Elmer's Tiny from the solid... The modified plans with the scaled down version are in pdf file format here (link in the 2nd line of the narrative):
http://web.me.com/ttrikalin/Machining/Elmers_tiny_1_4_(a).html
This is the half-finished crankshaft from last November... I intend to turn the crankpin by holding from the shaft (0.032" diameter -- beefed up, not to scale) by off-setting by 0.023"
I decided to mount a piece of delrin in the 4-jaw, and open up a hole that snuggly fits the half-finished crankshaft... like a home-made collet... (
seriously - delrin? *bang* )
Heres a peek through the stereomicroscope... It is a snug fit... the shafts diameter is a few tenths of a thousand larger...
I will turn the crankpin by offsetting by 0.023. Therefore I turned a reference surface, concentric to the initial hole that holds the crankshaft-to-be. This will help me indicate the offset.
A small dab of silicone to secure the connection... you may be able to see it spill out where the derlin and the crankshaft meet...
Next step, offset the crankshaft by 0.023 to turn the crankpin. Start at 0, indicating on the reference surface I turned earlier...
and finish at 0.023"...
Using derlin was a stupid idea... the connection is not strong enough, and the tool digs in and practically ruins the part... The photo says it all... another difficulty is that with such small parts the machine is relatively huge and there is little sensory feedback while you turn the dials... So i did more damage to the part than needed... but it is salvageable I think...
See the ugly turning job below... from within the stereomicroscope...
Any pointers welcome...
Oh well... next time...
take care,
t
