- Apr 26, 2012
- 93
- 46
Just finished this one - the 15th of Elmer's Engines to be completed here at Inky Engines - this one took a little longer than most of the previous builds.
I gave up early any hopes of emulating Stan Shire's build in the glamour and innovation stakes! This one therefore I consider to be an example of 'understated practicality'. To avoid any need to polish a fancy brass ladder and railings they're painted black! To aid maintenance and adjustment the rails are just pressed lightly as completed units into the catwalk and engine floor. And, as usual, Elmer's fiddly con-rod and valve pins are threaded and fitted with Nylock nuts.
Mineral oil rather than water is pumped to keep the plungers lubricated, and with the pump under load it will run on about 8 psi.
Hope you enjoy the video.
[ame="http://youtu.be/O8hj7Mmeic0"]http://youtu.be/O8hj7Mmeic0[/ame]
I'm really not sure what the next one is going to be, perhaps another Elmer, or I've been considering a 1" scale LC Mason Minnie traction engine - got the book, just need the courage to make a start!
Kind regards
Geoff at Inky Engines
Kind regards
