Double thanks Ken
; "lookenpeepers" - I like that term ;D
I got a call on Thursday; the brass stock I'd ordered a couple of weeks ago had arrived. Went to fetch it on Friday - two 2m lengths of stock well wrapped in shrink wrap... When I opened it at home yesterday evening, it was two lengths of 3 and 4mm round and not the hex sections I'd ordered :wall: - that'll teach me to check at the supplier. So Monday they'll be getting a visit *knuppel2*. Fortunately I can use the round section - especially the 3mm one.
On to today's bits. First off the fork links for the parallel motion. The rest of the engine seems to be evolving as a mix of aluminium and brass in sort of layers, so I thought these would look OK if made from aluminium rather than the brass specified. As I'll be using small bolts to substitute for the link pins, this can be done; if the original plans are followed some pins need to be soldered to these forks and aluminium wouldn't work.
I squared up a bit of 8mm aluminium plate, and clamped that on the tooling plate on the mill - with suitable packing, bits of paper to prevent slipping, and the vise stop also set to keep the X position for a later machining process. Then I drilled two 1.6mm holes to tap M2 on the left side, and two 2mm holes on the right side - using the DRO to locate them:
Then I shifted the one clamp to allow me to mill out some excess:
The workpiece was flipped, and more excess milled out:
Next, the workpiece was clamped vertically, and a slot milled in the top:
The centering feature for the DRO is really nice to use for jobs like this; take the edge finder, and zero Y on one side when it kicks out, then move to the other side, and when it kicks out, press "Y" and 1/2 and the center is located ;D
Before separating the links from the parent stock, the M2 holes were tapped; its easier to tap things when there's a bit to hold onto and flat surfaces:
A quick bit of work with the slitting saw - one cut at the length of the forks:
Two cuts to separate the forks from the parent stock - I used the height gauge to set the saw height for each cut. The gauge was set to zero at the height of the workpiece, and then adjusted for the required depth, and the spindle adjusted till the top of the slitting saw just touched the gauge foot:
Fresh after slitting off - still in need of the elbow grease toolkit:
After application of the elbow grease toolkit - and finished to match the brushed finish of the rest of the aluminium bits on the engine:
For the links, I milled some brass plate down a bit to get one straight edge on it, and sawed a long enough section off to form one link. Then I heated both bits up and dabbed with some electronics solder to tin them:
Then I set up the bits with their straight edge on a rusty bit of plate with one of my much abused but well loved toolmaker's clamps also lying on the plate:
The rusty plate is to prevent excess solder from sticking to it, while helping to keep the bits parallel. The toolmaker's clamp is to force the bits together after heating enough to melt the solder. Heat was applied and the clamp screwed up, and the brass plate bits stuck together.
The soldered assembly was milled to final width:
With most of the excess stock sawn off, the workpiece was centered, and holes drilled - 3mm on the outsides and 2mm for the middle one. This is much bigger than on the plans, but the reason will become apparent later in the build:
After more use of the elbow grease toolkit:
The engine so far - assembled with various odds and ends to keep things in place temporarily:
The chromed dome nuts does not look right. I've been trying all suppliers in Windhoek looking for M4 brass dome nuts, and all of them assure me that I won't find any. To quote one supplier: "Your chances are better at getting pregnant than finding brass dome nuts locally". Well,
- I think making them is easier (and quicker) than the quoted option ;D
Regards, Arnold
