I really struggled and got lost looking for a suitable carb. Was ideally looking for a WT-225 which is what the Kolm engines use, but could not source. Decided to try my luck with the GF40.
Still playing with the setup and have only managed to run it for a few more minutes as I need to be a bit respectful to my neighbors with the noise.
With the 26x10 prop, the range was 1300-4800 rpm which i'm pretty happy with without making any adjustments to the carb needles.
If i'm happy enough to put it in a plane I will likely use a pump which is common in commercial models (Kolm/Valach) of this type. That should at least provide a neutral pressure on the postivie side and let the engine suck what it needs.
For now I need to find somewhere remote that I can test and play with it (once lockdown finishes).
I also plan on trying a 24x10 prop.
