Following my first foray into electroforming, I shall attempt to collect my experiences here in order that anyone with an interest can assess whether the process is suitable for their part.
I find it useful to begin with a summary of the process and applications:
Electroforming material, for our home workshops, is practically limited to copper.
Parts may be created with any desired wall thickness, but thicker walls means more plating build and all the issues which come with it are amplified. 1mm is a practical thickness in my limited experience.
Wall thickness is likely to be uneven to some degree, depending on the shape of the part. A broadly semi-circular section oil sump, for example, would be expected to plate with reasonably consistent wall thickness, while a complex shape or one with small internal and external radii will build up more at the external radii and less at the internal radii.
Equipment and consumables are not expensive and are readily available (in the UK at least). The most expensive item will be the power supply, which should at least have a current reading and ideally have a current control (as opposed to just a voltage control). Copper sulphate, sulphuric acid, distilled water, metallic copper (e.g. domestic plumbing pipe), graphite paint, a fish tank heater and some plastic tubs will complete the set.
