i need help with a wiring problem like i had to replace a switch on the start stop reversing switch . which i copied the wire #'s on the switch itself but i had to pull the wires out of the main fuse block and i had them #ed and even the manual has them #ed but not color coded . and when i went to put it back the wires in the panel i found out that the #'s had come off. so there is 5 wires that needs to find their proper place. so if anyone could send me a photo of the power block or explain how to find the proper place for these wires . there is one white , 2 brown, one yellow and one blue., but on the other side of the block they are all red wires.
