- Oct 20, 2010
- 913
- 132
As anyone with a lathe knows no matter what size you could always use a bigger one. Sometimes the swing is to small, sometimes the bed lenght. This will not help you with the swing, but will help with the lenght. My Monarch is 20 BCC, so when a chuck and a drill chuck shorten the BCC to 14, your screwed if you need to drill a hole in the center of the work that 15". With these collets your drills mount inside the tail stock, giving you extra distance between work and tailstock. The bits will bottom at the drift opening in the collet, so there is not need for a drawbar to lock the collet in the tailstock.
A buddy of mine purchased at auction some large drawer storage units. Inside the units was STUFF, none of which he could use. I now have 500+ lbs of Stuff sitting on my floor, to sell for him.
Among the items are these drill collets, MT-1 & 2 limited sizes but will be real useful when the lathe need to be a little longer.
So I'm showing them here to see if anyone is interested, if so drop me an email or PM. There may be other sizes in unopened boxes, if so they will be included with the set if found. I will also include a MT2 to 1 sleeve "If found" There is one for sure others I have not yet seen. The sizes for the MT-1 and 2 almost dupe each other, MT-1 7/32, F, 11/32, 15/64, 3/8, 25/64, MT-2 1/4,11/32, 25/64, 3/8, 7/16. There may be 4 sets of MT-2, less of MT-1 at least at the moment.
drill inserted
drill inserted
