This site may earn a commission from merchant affiliate
links, including eBay, Amazon, and others.
Richard,
Yes that is a very good write up of how to use the old drafting board methods with CAD. I devised a very similar system but never made any attempt to write the work up. The problem with the system is it is a bit tedious and time consuming how ever it really made the gear math work in my head.
There are a free gear resources on the web that I have found for involute curves or approximations of involute curves.
The Rush Gear site has 2D and 3D gears for download. The curves are really circular segments which is a reasonable approximation of the involute curve.
http://www.rushgears.com/Tech_Tools/PartSearch5/partSearch.php?gearType=SPUR
Emachine shop has a gear module in the free software which will generate 2D CAD exports.
http://www.emachineshop.com/
At hobbing.com there is a free CAD library of gear profiles from 10-200 teeth.
http://www.hobbing.com/cadlib/index.html
Dan
I'd recommend the 'Gear Template Generator' from
http://woodgears.ca/gear/index.html
You can design the gear you want and export it to DXF. It also generates ring gears and racks.
