This post #3
I hope help
Installing program per 2001 (most older program be for 2001 used a 16 bit installer this will install older programs)
For installing copy all files to hard-drive
Use to install on 64 bit windows SETUP.EXE see files below . for installing AutoCad 95LT, AutoCad 2000LT and Plotupdate2000 (print drive only for AutoCad 2000LT)
AutoCad 95 may show error but still works after installing
AutoCad LT 2000 does not copy all files just copy all files from CD that did not copy the first time installing.
Set Compatabilty to Windows 95 to Windows ME be for installing
For floppy information need need for AutoCad 95LT I copy this AutoCAD 95 floppy folder on the hard-drive and I may a CD most computers today do not have a floppy drive I have one that pugs into a USB port from Amazon.
After Installing AutoCAD LT 2000 some files do not copy , Just copy the files not in AutoCAD LT 2000 files most are dll files
************ NOTE: Set Compatabilty to Windows 95 to Windows ME some time later versions for Is3 and Is5 intallers **********
**** Newer version of windows 10 v1903 and late the PDF printer do not work right just install a PDF printer for internet for works great ***
I hope help
My recollection of Linen is as a metal work apprentice in the Midland Junction workshops for the railways,1950.
The linen was rolled out on to the board and securely held down. I would have thought glossy side up but memory fades. The sheet was "sized" with a "pomme" filled with very fine chalk.
Apprentices always were very vigorous applying the chalk to ensure that the linen and nearby draftsmen received a liberal coating.
At a later date the compliment was returned with the fake ink blot and upturned indian ink bottle. All to the amusement of the office staff and chagrin of the recipient.
The drawing boards were of a large size set on a bench at above waist height. This meant standing to use them or perching on a bar stool to sit.
At the end of the day boards were covered with a cloth, not sure why.
Drawing instruments were German "Staedtler", I still have mine,,,,,,,,,,,,somewhere.
Drawing mistakes were made and these were removed with judicial use of a very sharp razor blade or scalpel.
later in industry drawing film replaced linen and pencil replaced ink. Time dictated drawing accuracy and freehand replaced compasses.
Enter CAD and that's progress.
Mago
