rklopp said:...approach one side of the shaft at a Z height such that the middle of the edgefinder cone touches the shaft surface. This will be at something like 30 degrees north latitude on the shaft, so to speak. When the cone "kicks" off to the side, zero the Z axis and whichever other axis is perpendicular to the shaft axis. Get clear of the shaft, move to the other side, get back to Z=0, then re-approach the shaft from the opposite direction. Note the reading on the other axis when the cone kicks. The center of the shaft will be exactly half the reading on this axis...
Bolster said:OK. That would be using a standard edgefinder at the 3 o clock position on the cylinder I assume. Should work well for smaller cylinders where you can get an edgefinder into the 3 oclock position.
