- Jan 6, 2013
- 84
- 122
Length of the saw is 100 mmThis looks fantastic,Mirek! What size is this cute little hacksaw?
I also use this methodIf you are able to solder then you can build up the cylinder quite easily, infact could probably just stick it together with JBWeld which saves a lot of material and milling time, similar sort of thing below
That will take a long timeThat looks GREAT!
Looking forward to seeing it running!
The work took about 20 days.Very nice looking build and very high quality work.
I noticed that you substituted ball bearings for the bronze bearings shown in the drawings; what were the sizes of the bearings you chose? Just for my curiosity, over what period of time did it take you to complete the engine?
I make everything on classic machinesAre you doing all of this work on manual equipment or do you have CNC capabilities at your disposal?
I have checked and cannot find those bearings. Do you have a link for a source? Are they self aligning bearings?
I always use the cheapest bearings from Ebay, made in China.Great job. I was wondering what kind of bearing you have used on the wheel shaft? I was developing a machine more or less like the one you have. the ball bearings that I had implemented on the wheel shafts where deep groove ball bearings at first but did not work properly. later somebody told me that I would get better results using angular contact ball bearings since they bear higher speed. any insight would be greatly appreciated.
