Doc Watson calling...
docwatson
Hello everyone from Devon, England.
I have just joined after buying a Sieg x2 clone.
Shop:Machine Mart
Brand:Clarke cmd300
I am a time served fitter with an engineering degree and computing pHd and am currently a lecturer in computing.
I will be using the mill for producing parts to fit into this.....
So first of probably many questions.... what is it?
Andy
Looks like something Lotus built, "Maybe" ?
wing box from a plane?
back of an old truck?
mil-spec version of an i-phone??
one of these.....
A 1966 Ford GT40 with a 4.7l v8 with webers.
Hoping to look something like this....
This forum comes up all the time with information about the x2 mill and I hope to contribute to that, then I need a lathe...tig...spot welder.... bigger shed....
See you on the forums
Andy
Wow, that's unique!
Have you retired EDF VTOL? Assuming you're the same Doc Watson. This goes back quite a few years.
Greg
Yes the very same...... as for VTOL... its under my bed packed away.....
Thrust was marginal and the ironic thing is if I go Li-Poly cells it would work now as technology has moved on.
Andy
