Hi,
I have just about got to the stage of running my modified beam engine and I'm wondering about the sort of oil to use in the piston and valve assembly.
One of the problems with model engines is that they run very fast compared to the full scale versions. I suppose this could be corrected using a governer of some sort but the idea occurred to me of using a dilatant lubricant where the viscocity of the oil increases with speed rather than decreases. This would result in slower engine speeds while retaining relatively high air pressures. While uncommon, these oils do exist and are used for chainsaw blades ( see http://www.motipdupli.de/?L=2&id=944).
Has anyone tried an oil like this?
If not, what would the recommendation be for a suitable oil i. e. should it be thick, thin or just an average auto engine oil?
Thanks,
Alan C.
Thanks,
Alan C.
