Journeyman
Hi, seeking advice for truing up a diamond cup grinding wheel. Trying to make a small drill grinding set-up. Using one of the small 3" grinders that are available to provide the power but need to install a 4" diamond cup wheel. The grinder spindle is 10mm and the hole in the wheel is 20mm so I made an arbor to fit complete with a left hand thread flat nut to clamp the wheel in place. Everything fits OK, wheel is a good fit on the arbor, the arbor is a good fit on the grinder spindle and the nut works fine.
Problem is as soon as I start the grinder at it's lowest speed (1000rpm) the vibration is horrendous, not inclined to ramp it up to 9000rpm. Without the wheel in place there is no vibration at all. The arbor runs true with no discernable runout. A dti on the wheel shows the flat face to run true but the outer edge is a good .010" out. The sideways displacement can be seen even with my ancient eyesight!
Have trawled the interweb but with little success except one place that seemed to suggest a gap between arbor and wheel and using a mallet to centre the wheel? So over to you, I am sure that with the wealth of experiance here someone knows how it should be sorted.
Thanks in advance, John
