It occured to me this afternoon while messing about with the valve timing on my new twin horizontal engine, that it would be nice to have some way to meaure the difference it makes in a small engines power output when the valve timing is adjusted. I can think of a couple or 3 ways of doing this. Probably the low tech method would be with a tachometer. Assuming that the air pressure and the inherent friction of the system were unchanged, "better" valve timing would give higher RPM, while "worse" valve timing would slow things down. Somewhat "higher tech" would be to drive a small generator and measure the change in generated amperage/voltage that result from timing changes. One of the rather neat ways of measuring would be with the "floating ping pong ball" method. This is a system I devised for measuring air flow through die passages of an injection mold. Any time that you have a stream of air coming out of a nozzle, the velocity of the cone of air exiting from a nozzle is greatest around the perimeter of the air stream. If the nozzle is pointed straight up, you can float a ping pong ball on the air stream, and it won't fall out because of the higher pressure/velocity around the outside of the air stream.--And the more efficient the air passage is designed, the higher the ping pong ball will float, because the more air will flow thru the passage.--I won a hundred dollar bet one time with a die casting engineer who thought his die design was superior to mine. We ran air at equal pressure thu his design and thru mine, with a vertical nozzle attached to the exhaust. My ping pong bal floated about 4" higher than his---unfortunately, he owned the company I was working for at the time, but thats another story----If you hooked a small steam engine to an air pump (aquarium bubbler size) you could measure a change in power output by seeing how much higher or lower the ping pong ball floated----
