Thank you Steve, coming from you that means something! I have used Alibre for CAD work ever since it came out and then I added Alibre CAM about three years ago. Yes it is a version of VisualMill that runs inside Alibre. It is not quite as sophisticated as programs like MasterCam but 2 things I really like about it: 1) since it runs inside Alibre if I make any changes to my CAD models the CAM picks up the changes immediately and modifies the tool paths to suit. That saves me a ton of time since I tend to draw and tinker and modify my way along with things as I design them. 2) It is fairly simple to learn and use so if I don't need the very highest end sophisticated tool paths it is quicker and easier for me to get the Gcode done. This is the first part that I cut on my new 4th using full 4th motion (as opposed to just indexing). It was fairly easy to program and so far making the chips has gone well and without error.
The local sales guy for Solidworks tells me that there is now have a version of MasterCam that runs integral with Solidworks. That didn't exist when I bought Alibre CAM. If I was buying again today I would research both programs but I am definitely happy with what I have and would likely go this way again due to cost. I have been able to program almost any part I want so far with ease and success. One important point though, Alibre CAM does not support lathe tool paths. I use the MasterCam seat that we have at work for lathe stuff or just program parts directly on the lathe control. That's easy on the Haas with Intuitive Programming.
I am looking forward to getting my version of your V8 design done and running Steve. Next up once I put the finish passes on the block (10 thou left for a nice finish pass plus boring all the pockets and drilling/tapping the bolt holes) will be the camshaft and crankshaft. I have the material in hand and I want to program both of those using the 4th axis as well which should work out slick but I haven't drawn them up in CAD yet so it will be a while I guess.
Cheers and thanks for the compliments!
Maxi
