After a number of starting attempts the crankshaft was turning heavy so I took the engine apart an the crankshaft was a bit distirtes at the front crankpin.
So , back to the drawing board. It was obvious that the front crankpin had to be silver soldered. Since the rear crankpin does only transmit a very small amount of torque there is no need to solder this one.
I re-aligned the crankshaft by fitting it in the two bearing covers together with one half of the crankcase.
Afther that, the solder joint was made, job done.
With the front crankpin fixed, ther was of course need for a split big-end.
Now there are various types.
A is the most common, B and C are less common, as far as I know, that is.
Now there are a few things to consider. I have a philosophy to use as many materials and parts I already have. The gears for the distribution were laying about in a drawer before I decided to use them. Gears are very expensive so this was an attractive option.
The only drawback was that they were rather small , causing the camshaft turming very close to the crankwebs. There is also the risk of the cam lobes hitting the big-end.
This rules out conrodtype A because the rod bearing cap had to be as small as possible.This leave type B and C. Giveen the fact that there is not much space in the crankcase , type C is not very attractive, leaving type B.
