What does the team think cylinder - piston clearance is ideal?
In this case the cylinder bore is 1.375", it is made from cast iron, and air cooled.
The piston will be made from aluminium and will have 2 rings.
The engine is IC and will be fairly slow revving, although not hit 'n' miss and will not be expected to work hard (demo running, basically).
The Emerald Isle
The Emerald Isle
