In the first shop I worked in, there was an old bottle of white lead for use on solid centers, but even then, in the early 70s, it was not supposed to be used, lead is toxic and the heat from using it for machining would make it into a mist/aerosol so you'd breath it in. Probably NOT a good suggestion.Try this from old timers in 1960's. The best to brush on white lead in oil 🛢.
Never try white lead.
I know it is very toxic and was band in California.In the first shop I worked in, there was an old bottle of white lead for use on solid centers, but even then, in the early 70s, it was not supposed to be used, lead is toxic and the heat from using it for machining would make it into a mist/aerosol so you'd breath it in. Probably NOT a good suggestion.
I have not heard of using Isopropyl alcohol for cutting oil. Use for cleaning off oil.This may sound crazy at least it did to me after 34 years of being a machinist. I never heard of this until I started my new position at a UC Davis as a machinist. A lot of time we use Isopropyl alcohol in a drip squeeze bottle. It has zero irritating fumes and leaves zero residue. I only use it on light cuts but it seems to work ok. Now I use it in my home garage machine shop just so I don't get smoke fumes traveling into the house. Because I here it from the family when they do. Go ahead at search it up on the internet an you will find more information about using it. I was also wondering if anyone else has or heard or used it? I also use water soluble cutting oil in a small squeeze bottle that seems to work ok. Kerosene and WD-40 are very irritating to me now they didn't bother me when I was younger, but I don't have a problem with cutting oil smoke.
Gary
I just use tap magic for about everything unless I can get some black cutting oil.
For threading aluminum and even some machining, Relton A-9, your wife might even like the smell though it would be fairly expensive.
WD-40 in the spray cans works for cutting 3/4"/20mm aluminum plate with a portable circular saw with a carbide blade, very noisy, requires hearing protection, face mask and something to keep the chips out of the back of your neck as you're cutting, and a second person similarly equip using the WD-40, but it does work. Been there, done that, but don't necessarily recommend it to others.!I have not heard of using Isopropyl alcohol for cutting oil. Use for cleaning off oil.
I have WD40 but only time used for cutting is when work at as journeyman repair machine and only thin had for a cutting oil WD40.
I have large can of WD-40 in my shop today and may buy can every 10 years. But do use for turning or drilling. I only use on bandsaw it outside in building by it self let wind blow . I think try every thing for bandsawing.WD-40 in the spray cans works for cutting 3/4"/20mm aluminum plate with a portable circular saw with a carbide blade, very noisy, requires hearing protection, face mask and something to keep the chips out of the back of your neck as you're cutting, and a second person similarly equip using the WD-40, but it does work. Been there, done that, but don't necessarily recommend it to others.!
I have used it in past I like it when dating but did not like the price. The crew got dark oil.For more than fifty years I have used Tapmatic and have been very pleased with it.
I used a condom when I was dating.I have used it in past I like it when dating but did not like the price. The crew got dark oil.
It was like a after shave.I used a condom when I was dating.
Bacon grease instead of a condom? Never tried it. HOwever, I used to know a guy who had kidnapped someone, tied him to a tree in the forest, put some bacon on him, apparently as a lure for b ears, but the guy tied up got loose and called the cops. Hmm. I like bacon grease sometimes to use to pop popcorn. Like the flavor.I've read some old-time machinists swear by bacon grease. Never tried it myself; has anyone here tried it?
