SignalFailure
- Jan 1, 2008
- 366
- 3
I've seen lots of engines especially wobblers that call for a curved slot on the reverser. I needed to make such an item for the current project with a 2mm slot within 1mm of the edge. Not having any fancy milling gear I tried chain drilling one but the result was very ugly and innacurate so I decided to fabricate one using only the lathe and some silver solder. Hopefully someone might find this useful.
Basically it consists of three discs - the main 'outer' disc (I used a 10mm end mill to make the 2mm deep recess... ), the central disc, and a ring with a sawn out section for the middle bit. I placed this ring carefully over the plans and marked off the part to be removed.
I made the two inner parts deep enough to stand a little proud of the outer ring so I could face it off nice and tidy after soldering. Hopefully the pictures explain all. Now I just need to drill another two holes and it's finished ;D
Paul
Paul
