Bentwings
I was talking to a couple of my old racing friends and the twin engine dragsters came up. I then thought it would be a cool project for an enterprising model engine maker to add to the collection. Since that was during my growing and racing days and I knew many of the twin guys we often talked about them. There were a number of early favorite connections. The inclines were the most successful. The early coupling was with at least a four row chain and double row sprockets. Chain metallurgy has come a long way since then but that was the weak link in that system. One supplier of custom axels created the gear coupling which joined the front and rear of the crankshafts. The small block chev guys had crank problems with the front snout getting ripped off. The fix was to graft a big block snout on. It was a complex machining operation but the custom crankshaft suppliers simply built custom cranks with the big snout. Eventually the snouts became splined which solved the broken key ways of early designs. Today you could purchase a gear coupling but most would simply make it splined to start with. Certainly it would be a big but fun project. Building model v8 I would engines is not to be taken lightly but building them with the idea of coupling them from the start would get around the more complex issues. To make it even more interesting a Dyno could be built measuring torque which is easily converted into horse power. It doesn’t need to be confined to v8’s as about every type of engine has be tried as multiple. Briggs and Stratton are even done for cart racing. My interest is in radials but coupling them is not in the picture. Internally maybe but I haven’t explored that.
