Hi Everybody !
What kind of water do you use for cooling ?
Thanks !
Thanks !
I am not using TRIM straight it is mixed with water same strength as the coolant I use. Not sure what you mean by your comment?Docs 'consecrated' coolant might be ok, but only if you are relying on divine guidance for protection
The wet stuffHi Everybody !
Thanks !
Steve do you use the pre mix or do you use the consecrate I see on the bottle it looks like they mix with de-ionized water. Was just wondering if you mixed with regular water. I know the trim keeps rust to a minimum but after awhile it needs to be thinned out. Is it the same with the Water wetter?
Doc, I think it was a little tongue-in-cheek humor based on the way "concentrate" came out in your earlier post - I presume the victim of auto-correct.
Yes I went back and re-read my post LOL some times auto correct is a pain lolIt was, sorry, I couldn't resist
adjective: consecrated
- (of a church or land) having been made or declared sacred.
"a Christian burial in consecrated ground"
