I am going to split off a topic that was posted in another thread, since I think we drifted too far off of the original subject that was posted.
Lets assume I am sketching in Solidworks:you select circle and click and drag a circle but what diameter is it.
Typically I extrude from the center out equally in both directions, and again there is a window on the side that tells me how long the extrusion is.You then extrude it but have to enter a length or do you just drag it to some unknown length.
For a shaft, again draw a circle, and edit the radius in the box on the left.The other part how do you get the hole in it to fit the shaft if you don't dimension it or give it a size.
I always draw a centerline at the X,Y,X axis, and then offset that centerline over a specified distance.And how do you position the hole in the block if you can't dimension it from an edge or ctr line.
Maybe I am using those without knowing it, but I really don't think I ever use any of those.I'm constantly using various constraints particularly concentric, parallel, symmetrical, tangent, colinear, right angle. Some come up automatically others I add as needed
