Jennifer Edwards
- Aug 9, 2018
- 215
- 90
I'm selling my complete shop including the following:
Axminster SC2 Lathe
Axminster SX2 Milling Machine
A Linisher
Wheatstone Sharpener
five drawer roll around tool chest linisher and sharpener is on
Foredom tool with foot pedal control
Complete set of collets from 2 to 20mm plus MT3 collet holder for mill
Four jaw independent chuck
Four jaw synchronised chuck
Three jaw synchronised chuck
Lathe faceplate
Rotary table
Rothenburger torch for silver soldering with some silver solder in paste and rod form as well as flux
Dial center finder
Digital micrometer 0-50mm metic and imperial
5-30mm inside micrometer
25 to 50mm inside micrometer
50 - 200 mm dial bore gauge
Solid Granite surface plate
Lots of metric and imperial taps and dies
Cast iron combination square plus anther inexpensive one
Dial indicator with magnetic base
At the faceplate
Nice clamping kit
2 Jacobs chucks, one MT2 one MT3 for lathe and milling machine
One small jacobs check on a quill for fine drilling
Drills from .8 to 12mm
10 piece Glanze tool holder set with tons of inserts
25mm 3 insert Glanze end mill with plenty of new inserts.
Plenty of end mills
2 matching metal stands with shelved cabinets for the lathe and mill
Five drawer roll around cabinet for tooling and whatever
Two nice LED bench lights also two small LED lights on mil and lathe.
Shop vac
Plus a ton of other miscellaneous tools and equipment for model engineering... just about everything you see in the pictures.
Also a compete casting set and complete set of full size drawings for a three cylinder 1/4 scale Anzani radial engine.
A bunch of metal bits Bronze, Brass, Steel, and Aluminium, including 3” cast iron bars for three sets of Anzani Cylinders
All of my equipment is two years old or less, has been lightly used, and lovingly cared for.
I wish to sell the complete setup in one shot and not break it up.
You must arrange to pick it up from my location here in Bridlington, East Yorkshire. I will consider delivery within 250 miles if you pay for the van rental and petrol.
if you have questions i will be happy to answer any and all. e-mail me at [email protected] for my contact info.
My firm price for everything is £2,200
Axminster SC2 Lathe
A Linisher
Lathe faceplate
Rotary table
Dial center finder
At the faceplate
Nice clamping kit
Plenty of end mills
Shop vac
