I have built six i.c. engines in the last 5 years and I am happy with all of them and how they run. What I am not happy with is the constant mess of oil that I have to contend with every time I run them. For one thing, I don't have an oil-can capable of reaching into hard to access areas and dispensing one or two drops of oil. I am going to research a hypodermic syringe with a long steel needle that can reach in and dispense only one or two drops where I want them. I will probably build another engine sooner or later, and would like to consider a closed crankcase engine. Like, how hard can it be? I would probably use sealed ball bearings on the crankshaft main bearings, and probably have the camshaft extend through a boss on the side of the engine housing, with external cam gears and an oil seal on the shaft where it exits the engine case. The engine case would, of course, have to be split with a gasket between the two halves, an oil drain, and an oil filler cap, positioned so as to prevent over filling the crank-case. I don't know exactly what I would do to lubricate the con rod big end or small end. If I partially fill the crank-case with oil and use splash lubrication, that would probably work, but then I might have to have an oil control ring on the cylinder. My engine would be a four stroke, not a two stroke, so mixing oil with the gasoline and having the gas/oil vapour circulate thru the crankcase on the way to the carburetor would not be an option.--But then again, perhaps it would be an option, especially if I run a Viton o-ring on the piston, as they do require some lubrication to prevent premature wear. I would like to hear suggestions, points of view, etcetera from other i.c. engine enthusiasts in regards to this issue.---Brian
