Holt
- Oct 14, 2010
- 164
- 4
Last week one of our EDM machines had a faulty glass scale and the technician decided to change it for a new one, i scored the old one, and will try to clean it.
Both ends of the scale can be removed, both ends are held in place with 2 philips screws and some silicone
The technician pointed out how dirty the reading head was, by braking the PCB off the head.
Fortunately i could glue it back on with epoxy after cleaning the lens and reader with 99% isopropylalcohol
I dropped a string through the scale and tied a piece of cloth from the optician at the end of the string, and pored some isopropylalcohol on the cloth, and dragged it trough the scale taking care to keep it at one side of the glass, so i knew that side was clean.
Then i did the same on the other side of the glass, i put a piece of foam inside the cloth to compensate for the larger space on that side of the glass.
The cloth reveals that it was about time to clean the scale
The reading head can only fit in one direction, and it's easy to see how.
Now the ends shall have some acid free silicone and the 2 screws, and the scale works like new (i tested it at work, on a lathe DRO)
