Correction, it is a milling vise!!!
It just needs a good cleaning and some new jaw inserts and it will be ready to work again!
SWMBO came downstairs to see what i was up to and made a few comments.
She did not like the colour of the mill.
Some of the machine grey had worn off and the white primer was showing through.
No big deal to me since it is just surface and does not affect the way the mill will work.
Apparently that was not a good enough answer....
So out with the degreaser, rust remover, paint stripper and TriSodium Phosphate...
So far i have the knee all stripped down and primed.
The front door of the cabinet is also primed.
Still a long way to go....
But it will be good once it is all done and back together! ;D
Any recommendations on paint in Canada??
Looking for something that can be brushed on and is very hard when dry.
Research on the forums has shown Alkyd Enamel paints and oil based paints.
Also looking at implement and equipment enamel paint from TSC stores.
Will post pics of parts when done or of anything interesting!
The gears in the head are all in pristine condition, which is very good!
The little bit of play i felt in the tables was due to the leadscrew nuts being loose!
Andrew
