So I need to build the frame in the pictures, it is from withe aluminum comercial profile 2x 3/4" or so...
In one side of it, I planed to put acrylic and in the other side a metal sheet. Inside in the bottom (the narrow end)
put a neon ligth and voila... we get some decent ilumination for a small private pub.
So the question is, how to joint the C channel and the square tube...
I cant weld, because it will damage the withe paint.
I cant rivet, because as you can see, it isn fully backed in the c channel (space to slip the acrylic)
I cant use some long screw because I need the C channels as flat as possible. (see the picture)
I remeber saw some time, a sort of "expansion nut" If this will aviable I can put one in the inside of
the squere pipe and drill the C chanell, and use a chammfer screw for joint stuff together.
Any body know the rigth name for this? or maybe has do something like this?
I allready try to find this on the web but I cant find nothing like I need.
Kind Regards. Alejandro.
