I vaguely recall from the ancient days (pre-1985) that I studied non-electrical topics in Physics I & II, and as I recall we were forced to take Thermodynamics, which I hated.
We called it the dreaded "Thermo" class, and it seemed more like Chinese water torture than anything useful for EE's.
I am sure I never had any fluid dynamic classes.
I remember PV=mRT
As far as Bernoulli's principle, I have never been able to wrap my head around that.
I can understand electrical, basically because it cannot be compressed, and it acts like water flowing in a river, with the branches all summing to equal the flow in the main river channel.
Voltage is analogous to pressure, amperage is analogous to current flow in a river or a conductor.
Resistance is like dikes and obstructions in the river.
Electrical transformers typically have a higher voltage (pressure) on one side, and a lower voltage (pressure) on the other side.
Reducing the voltage (pressure) increases the current (flow).
I visualize the Bernoulli image as a large pipe (wire) on one side, which intuitively means high current, low pressure (voltage) in the electrical world, and the small pipe (wire) would be high voltage, low current.
But this is the opposite of the actual Bernoulli lower pressure on the smaller pipe size.
So this is the opposite of what visually is seen in the electrical world, and thus difficult for me to wrap my head around.
I don't think you actually change the speed of electrons in the electrical world, and so there is no velocity change.
I can visualize the effect of power factor in the mechanical world, which is a surge tank.
A surge tank acts exactly like a capacitor or inductor, ie: they all store energy.
If I crimp the end of a garden hose, I can spray water a long distance.
The same water flows out of the hose (I guess) whether I crimp the end or not.
If I crimp/bend an electrical wire, the same current flows through the wire, so no analogy there.
It is a bit of a culture shock to go from the electrical to the fluid dynamic world.
Sort of like driving your car, but turning the steering wheel left moves the car right, and vice versa, or stepping on the brake pedal makes the car go faster, and stepping on the accelerator pedal slows the car.
Its all mixed up in the fluid world.
