Arnold, thanks again for looking in. I appreciate your keeping track of the thread!
Steve, Thanks! Like you and Arnold note well, I do seem to find some slightly out-sized projects for this little lathe. The physical dimensions of the Taig lathe belie it's upper capacity, though when turning things like this, it does eat up a bit of time. It certainly is a rigid little thing, and the spindle is just plain tough.
Starting work on the fly wheel spokes.
For the spokes, I started out with a couple of pieces of 4" x 4"x 1/8" CRS and cut the corners off to get rid of
what waste I could. I drew a copy of the pattern to help with locating mounting holes that would be used
for machining, but would later be cut away as waste. Mainly, I want to make sure I don't put a hole in the
middle of what will become a spoke.
A couple of punch marks are made through the paper template for holes to mount the pieces to a face plate.
I also put a punch mark in what would become the approximate center of the spoke piece so I could eyeball a
location through the back side of the face plate. The center is not critical at this point, but will help getting
things somewhat centered to start with. Then the both pieces are tightened down.
The corners are cut off and the pieces brought to size using the old Craftsman. I used the Craftsman for
this step because it is a little bigger than the Taig, and I could get a cutter pointing straight into the interrupted
cut that the corners of the steel plates present to the tool bit.
Then it's center drilled and drilled through 3/8". After this step the piece is put back in the other lathe. I made
a spindle nose for the Craftsman so it will take the chucks from my Taig lathe. That way I can transfer work
back and forth between them without having to do any additional setup. Just take the chuck with the work
in it from one lathe and slap it on the other and everything remains centered up.
The hole in the plates is then bored out to take the hub that will hold the spokes to the crankshaft.
For the next step, I need to spot the holes in the fly wheel plates. The holes will form the bottom of the
spokes where they come to the center of the fly wheel.
I made this auxiliary spindle a few years ago, just for doing this kind of thing. It has a center hole in the chuck
shaft, so it's easy to get it centered, which is what is being done in the picture above.
Here's my setup for drilling the spoke bottoms. The aux spindle is cranked over to give the radius needed for
the spoke holes. There will be six of them, and they are indexed using the head stock plate. The DI is used
so I don't drill clear through the spoke plates and into my face plate.
After all the holes are spotted they are drilled through 3/8".
This shot should give an idea of what the finished fly wheel will look like, if I don't screw up too badly.
Here is today's progress shot. Photo credit to Rudy Kouhoupt.
Next, some head scratchin' to work up a pin plate jig for cutting the spokes. Rudy did it with a hacksaw. I actually
do get nice curvy lines when using a hacksaw. I never know which way they are going to go, though.. I may
have better luck using an RT.
Dean
![56.jpg](https://proxy.imagearchive.com/d63/d6369bf0415a13898c7f820a88a7056a.jpg)
![57.jpg](https://proxy.imagearchive.com/a70/a7087dd0284d28dea472cdcc739f23f4.jpg)
![58.jpg](https://proxy.imagearchive.com/287/2877b169e4fda9e9ec948349dc15c478.jpg)
![59.jpg](https://proxy.imagearchive.com/3a0/3a03fb8a18577e88084e342ebac18db3.jpg)
![60.jpg](https://proxy.imagearchive.com/459/4591c4f3a551394fa483f024451971db.jpg)
![61.jpg](https://proxy.imagearchive.com/bd7/bd7b208afbe8802277d9d98ce6bd598b.jpg)
![62.jpg](https://proxy.imagearchive.com/5f5/5f5e2539f10a330033ec8aeedc1c46c6.jpg)
![63.jpg](https://proxy.imagearchive.com/e9b/e9b8cff8cd294539ae8f932351b4557f.jpg)
![64.jpg](https://proxy.imagearchive.com/6f7/6f7fd5829fa62b0cbdd9f9af963ac4ea.jpg)
![65.jpg](https://proxy.imagearchive.com/862/862d800bc1133f54dd4ba865d9965059.jpg)
![66.jpg](https://proxy.imagearchive.com/2d1/2d1ece01c44a1103a1c603c62ad9ea93.jpg)
Dean
