I'm after some guidance on manually cutting a BSPT female thread form, for a 'sub 100psi' pressure vessel project, in situ.
The vessel is already prepped with a welded slug in the centre of one of its heads. It will, finally, be pressure tested.
I have a 3/4" BSPT hand reamer & Tap, but am unsure how to proceed next...
Do I drill undersize of the threads' minor diameter and ask the reamer do the rest?
Should I be fabricating a guide jig for the reamer (to keep it straight)?
Is there an easy method of how far to ream, & tap other than trial and error?
When I stop cutting with the tap, won't it leave fluted cut marks on the internal thread?
What is the tightening sequence for this fitting (Turns Past Finger Tight)?
Can anyone offer some advise, direction or recommend some good reading material?
