Hi. Can i use a DC01 or s355 steel for repair cracked Ford Transit frame?
I want to bend 2 angle and weld it to frame
Welded, spliced and repaired many truck frames large and small. Never a problem. Clean , common sense , and a decent weld. No problem.
Jack,
Have you checked with your dealer or someone knowledgeable about the steel used in your particular frame? The low carbon steel frames used in older vehicles were easily weldable, but auto makers today sometimes make use of high-strength low-weight alloys, and the Transit may be one of them. Some high strength alloys are prone to cracking after any welding, some require heat treatment afterwards, and some require special the use of special filler metals. I've seen some frames on commercial vehicles that were stamped with the warning "No Welding on Frame." - Terry
