bouch
- Dec 16, 2013
- 87
- 45
It seems like I only update my thread every year or so. I guess that says a lot about how quickly I get work done...
I have done some more work on this big engine. I've managed to build the steam chest, piston rod, piston, and a bunch of the studs needed to hold everything together.
The steam chest was cut from solid, using only a drill press and a shaper. No milling machine. (combination of my home shop's milling machine is out of commision for various reasons, so I need to drive up to my father's shop, an attempt to get those nice square corners no one will ever see, and also just to be able to say that I did it that way)
"4 corners, neat and square" (bonus points if you get the reference!)
I've also built the steam chest cover, but that's pretty boring so no photo. You can also see the valve rod gland has been made.
The piston and rod are built as designed, The taper worked like a charm, everything is nice and concentric. The slots are cut to fit some 1.5" cast iron rings I acquired. Not sure if I'll install them, as I don't expect to need to do any real work with this engine.
If you look at the 3rd photo, you can see where the hole in the piston is a little larger than the rod. That's because I cut the tapered section a little "overlength" to make sure that it engaged fully. You can also see the piston rod gland has been made.
Finally, a bunch of studs. These are for the cylinder heads and the steam chest.
Unfortunately, I'm out of material for more studs, and I have a bunch more to make (cylinder mounting studs, crosshead guide mounting studs, crankshaft bearing studs. Anyone know where I could get some steel rod appropriately sized for 10-32 studs? (.190 dia)
No photos yet, but I've also started work on the porting of the cylinder. I have the ports cut in the valve face, and the "steam line" from one port to one end drilled. Still need to do the other side and the exhaust port. I'm hoping to have the cylinder finished by the end of the year, and then I'll start working on the crosshead
And for a different project, I did download FreeCad and start working on 3D cad. Here's the first part I printed (at shapeways).
Its the pedestal for a 3/4" gauge caboose truck. Had a reasonably steep learning curve, but once I figured out the concepts, it went pretty well. I still did a bunch of stuff "trial and error" (mostly error), but I got it done. I've designed a few other pieces, need to get them printed and cast...
