Encouraged by all your recent comments here is the latest instalment in my Mill Engine build ...
I've never built a displacement lubricator before so I thought I would try to make one for this engine. I had a look around for ideas and found some basic plans on the internet to work from.
Fortunately I had recently purchased a set of micro drills and this was a good chance to try them out. They worked very well and I managed to put six tiny 0.5 mm holes in the end of my little drain valve with no problems.
I knurled a piece of brass and soldered it to the shaft after cleaning it up into a tiny disc.
This photo also shows the bottom of the lubricator which I machined with a nice curved form tool.
I always enjoy making knobs and the top adjustment knob was probably the smallest one I have made so far.
I dished it out with a ball nose end mill and used a form tool to radius the edge. I then scalloped the sides using the side of an end mill and a hex collet block. This photo shows me cleaning up the threaded section trimming it neatly to fit the little 7ba nut that retains it.
Here are all the parts ready to assemble. I don't think I quite got the o-ring right but it should work ok regardless.
And here is the finished lubricator mounted on the engine. It might be a while before I can determine if it works but I think it should be ok.
