arnoldb
- Apr 8, 2009
- 1,792
- 12
I'm trying to get my head around all the basic calculations that goes into designing boilers, with a specific interest in all-copper boilers silver brazed together.
A good amount of my hobby time have of late gone into trying to get together and understand as much information in this regard as possible, and I think I have a fair understanding of what is needed in terms of calculating pressures / material thicknesses and how safety factors and material strengths and temperatures are incorporated in those when doing calculations related to boiler shells and stays.
So far, my reference material has included KN Harris's book on model boilers and construction and information I could find here on HMEM, as well as some Google finds - unfortunately I have nearly no information on this subject in my own "library".
One aspect of calculating that I can't get a clear understanding of, and find little information relating to, is formulas needed to do calculations related to the "external" pressure limits / thicknesses required for flue tubes, and that is where I would like some clarification or help if anybody is willing.
One good thread started by Rich I found here on HMEM - with some formulas provided by SandyC.
For reference in the formulas that follow:
P: Pressure in psi
S: Maximum allowable stress value of the design material at design temperature
T: Tube wall thickness in Inches
D: Outer diameter of tube in Inches
Sandy's formula for calculating the maximum operating pressure for a flue is:
a) P = S [2xT 0.01 x D / D - (T - 0.005 x D)]
I'm not entirely sure how this formula is to be interpreted as written (No offense to Sandy !) - I _think_ it could be:
b) P = S (2T - 0.01D) / (D - T - 0.005D) ?
If I use the formula specified in the same thread for T:
c) T = (PxD / 2xS + P) + 0.005 x D
Which I think means :
d) T = (PD / (2S+P)) + 0.005D
And try to work it back to find P, I always end up with:
e) P = S(2T-0.01D) / (D + 0.005D - T)
Which is close to the original one for P as in b) , except that I get a positive instead of negative 0.005D in the "Divisor" term on the Right hand of the equation.
Given, I may have made a repetitive mistake, as my algebra is a bit rusty, or I could be misunderstand either or both the original formulas as specified for a) and c)
Another simpler formula I found on the Internet ( :-[ I didn't jot down the reference site!) is
f) P = 2ST/D
with the source specifying that this is an "Ideal" (Hypothetical and in the Ideal World) formula for "Thin Wall tube" usage, where the internal stresses/strengths and deformations between the difference of the outer diameter and inner diameter of the cylinder being pressurized is not taken into account.
The formula in f) is visibly close to the one provided in a) and I suspect the "complications" in the formula in a) compared to f) are due to incorporating factors for deformations and inherent material properties. However, when calculating P from formulas e) and f), the result is very close.
So, am I barking up the wrong tree ? - Did I miss something obvious ? - I'd really like to get a better understanding of this particular facet of boiler design.
Any input, suggestions and help will be most welcome - even if somebody wants to bash my head in for being a nitwit ;D
Kind regards, Arnold
(And apologies If this lot gave anybody a headache!)
P: Pressure in psi
f) P = 2ST/D
