Bevel gears. HELP.
fuzzymuff
Hi. Would there be anybody from the UK that would be interested in doing some bevel gears for me. They are out of a 1/8 scale diff. The large gear is approx. 14.5 mm dia. The smaller gear is approx. 12.5 mm in dia. I need 10 of the large gear and 10 of the small gear. They are made in brass. I am sorry about the shadow on the pictures. If you are interested please contact me. I am getting desperate.
Thanks for looking.
Graham
It's very time consuming to make miter gears due to the multiple cuts that must be made for each tooth. I would try find a supplier first because having someone make them could get quite pricey.
gbritnell
Are they not available from the the r/c car parts maker?
Tom
Hi Tom.
I can get alternative gears at a cost of £65.00 per set . My problem is they have to be the same as I am reproducing an exact copy of a diff.
Thanks Graham
I hate to say it, but Mr Britnell is correct. I have made a few gears for myself and I can tell you that you might be better off paying the 65 Pounds. It takes a bit of time to make gears.
Tom
