I saw this engine first on HMEM, there was a wonderful l post on the build of one ,and there are several beautiful, beyond perfect examples
of this engine on HMEM and on the web.
I run my "steam" engines on air at shows and at home . So my approach to this build was biased by my
desire to run on low pressure air. A good tip was also mentioned on HMEM that said " don't even try to build out of anything but cast iron "
because it is so out of balance that the mass is needed.
Sorry I am not going to look up the contributors names. But thank you.
Well with this in mind I made the crankshaft 2 piece, with a 2 ball bearing main block , and an outer BB bearing for a power take off and flywheel support.
I counter balanced the crankshaft as much as possible. This required some changes to the valve links, minor.
I also lightened all the above crank weight by making the parts out aluminum not steel.
I also found that air consumption can be an issue for my air pump, so I reduced the cylinder bore to .75" .
Because is it just an air demonstration engine I made all the wear components out of Delrin with Teflon packing.
So the pictures/ video are of my completed but not polished or painted engine. runs great IMO. 4psi aquarium - large volume air pump.
One more comment, almost all the metal used were gifts from friends,
enough bla bla bla. Here is the tube link
