- Mar 8, 2012
- 249
- 111
Hello to all,
I was away from this hobby for quite a while..I am 73 now and decided I needed to play again..I came across a partly built Bentley BR2, well actually 2 of them..They were being made in 1/3 scale..It appeared that there was quite a bit of work already done, and it looked pretty good..When I received them and started going over everything, I started to see that there were many things that did not suit me and some things left me puzzled as to the original builders intentions..The first thing that I realized is that the 1/3 scale did not follow through, and as an example, the crankshaft was short as to what it should be for the scale, and then the main mount was nothing like what a BR2 should look like..
OK, there is a brief summary of why I am doing what I am doing..I want to bring it closer to scale, and will change what I think necessary to do so..I will post pics as I go and will start with a comparison of the way it was and the way it will be..On the left is the way it was..Disregard the date,never setup camera..
In the first picture above, you will see that the crankcase was much thicker than what it should have been..There was plenty of metal, so I was able to narrow it by .400 total..It made a big difference in the look already, because it also tapered it up from the front and rear cover, look at the pics..
The above picture gives a rough idea of what I wanted to do....
I had to re-taper it to meet the cylinder ..
You can see how it changed it making it much closer to what it should be..
That is a good start for now, and I will explain all other changes including making the main mount look like a BR2...….Joe
