- Aug 7, 2014
- 57
- 68
Hi,
I am trying to create the intake/exhaust tubes for my radial project and not doing so well.
The material is 5/16" brass tube with .014" wall thickness. The issue is that the cerro metal that fills the tube is cracking during the bend process and causing a stepped appearance, see pictures.
I treated the tube by heating it to a red heat color then let it cool slowly, then filled the tube with cerro low temp metal before using a wheeled bending tool. When the bend was in progress, I noticed (felt and heard) that the cerro metal cracked when bending the tube causing a slight stepped finish on the outside diameter of the bend. I did exactly the same on the next piece but not to the same degree. Is it normal that the cerro metal cracks within the tube? I thought it would be mallable to some degree without cracking within the bore.
Has anyone had experience of this and is there a better technique, The tube between the cracks looks okay, but it does affect the appearance of the tubes and these being the intake tubes, they will be very visible.
I would be grateful if anyone has some good advice.
Many thanks
Steve
Many thanks
Steve
