Bench mill column
Anyone check how square their column is with their table on their bench mills? If so is there anything you did to straighten it up if it was out?
I have a precision Matthews pm-30-mv that has been converted to a CNC mill. I was able to put a tall granite square on the table and check the column with it, and I had more runout that I was hoping. It probably isn't enough to be worth messing with, but I've been considering making a tapered shim that'll fit between the column and base to straighten it up.
