isaiah lowe
Looking to make a 3 cyl 2 stroke scaled down snowmobile engine design with a few questions!
- bearings? Will it get enough lubrication with a sleeve Or shall I try find a needle bearing small enough?
- new to machining just bought a small mill and metal lathe I have been on here for quite some time in interest and am just getting started up now! can someone point me in the direction of some basic machining skills that would help me for making an engine
-spark plugs !
Can I make my own spark plugs from a turned down bolt would love to know what people have used for insulators that will withstand pressure and heat
- crankshaft seals
What do you use
-spark plugs !
- crankshaft seals
What do you use
