Having done quite a lot of boring on the lathe with a between ctrs bar and the work moving I would say you need a more rigid setup than holding at one end only.
Does your lathe have a decent tee slotted cross slide as that makes mounting work a lot easier than those that just have a small area for the top slide to mount to.
Also bear in mind in all those that you have seen the hole was being bored for a liner. The more critical bore that the piston fits was machined into a separate easily held liner. You are looking to cut the cylinder bore direct into your casting so a more critical setup. The liners also only make contact top and bottom often two slightly different diameters to aid insertion so far less critical of the need for those two bore to be totally parallel unlike the actual cylinder bore.
